Activity Forums VEGAS Pro Crop causes incorrect interlaced output
  • Crop causes incorrect interlaced output
    Posted by Luc Enders on July 6, 2009 at 12:23 am
    Anyone encountered this issue before in Vegas (both 8 and 9):
    – New AVCHD project with deinterlace set to none and field order upper
    – Add an AVHCD clip and crop from 1920×1080 to 1280×720 (centered)
    – Output to uncompressed YUV and (default) field order upper
    Now when I re-compress and deinterlace that file I get deinterlace issues in the progressive file: I see lines as if it’s not deinterlaced. One theory perhaps is that the processing order is incorrect: it crops the interlaced picture first and then outputs that interlaced. But it should first deinterlace, crop and then output interlaced.
    Luc Enders replied 17 years, 2 months ago 1 Member · 1 Reply
  • Luc Enders
    July 6, 2009 at 12:58 am
    Actually I found it only repro’s if I have a clip before and after that. If I just render that single cropped clip everything is fine. Weird.
