Activity Forums Adobe Premiere Pro Critique sought on my equipment picks for Hi8 analog to digital transfers
  • Walter Soyka
    December 2, 2013 at 6:15 pm
    [Joel Benedict] “It also has a 4-conductor FireWire 400 cable as a bonus; I’m wary about using it as the transfer method because: first, it’s Sony’s proprietary i.link version, which might be less than compatible with any cable or card adapters to the larger FireWire 400 format, or even if it is physically compatible, might not be supported by any capture software; and second, because doing the transfer from analog to digital in-camera might introduce noise, and the capture quality might be inferior to what I would get from a separate DV cam pass-through.”
    If you want to use DV for ingest, then you will have this analog to digital conversion (and any attendant artifact introduction) at some point. You may as well try this first.
    I wouldn’t worry about the i.Link/FW400 thing — it should work fine for capture, although you may or may not have device control.
    Your other option is to get an analog capture card card. Your cheapest option is probably the Blackmagic Intensity line.
    Walter Soyka
  • Joel Benedict
    December 4, 2013 at 3:46 am
    Thanks for the detailed reply and further equipment recommendation! The Blackmagicdesign Intensity Pro HDMI and Analog Editing Card PCIe version would be $170.99 if bought off Amazon in new condition, $127.53 if bought used off of eBay. The PCIe version has higher bandwidth than the USB 3.0 version (albeit less portable).
    https://www.amazon.com/gp/offer-listing/B001CN9GEA/ref=sr_1_1_olp?ie=UTF8&qid=1386127875&sr=8-1&keywords=Blackmagicdesign+Intensity+Pro+HDMI+and+Analog+Editing+Card&condition=new
    https://www.ebay.com/itm/Blackmagic-Design-Intensity-Pro-HDMI-and-Analog-Editing-Card-/161166145149?pt=LH_DefaultDomain_0&hash=item258640367d
    It would be a good idea to buy it if I wanted to avoid something else I just thought of, which is the bandwidth cap of 4-conductor FireWire 400, but then again, the analog bandwidth cap of RCA stereo cables and S-video will be there regardless of the digital cap; FireWire probably has enough bandwidth to pass the signals through.
    I’m probably going to buy the TRV320 regardless of the digital output–I have to have something to play the tapes in stereo after all. I have a DVD player with analog inputs to test that signal, but to test the FireWire quality, I’m going to have to gamble a whopping five bucks on a 4-conductor FireWire card ;). If the quality is inferior to the analog test (e.g. electronic noise, video artifacts or compression), the Intensity Pro is again worth of consideration. Plus, I can always resell the BINTSPRO (as it’s known in the second-hand underworld) after I’m done with the transfer job, or use it to capture vintage gaming console footage.
  • Walter Soyka
    December 4, 2013 at 4:13 pm
    [Joel Benedict] “The PCIe version has higher bandwidth than the USB 3.0 version (albeit less portable). “
    Don’t worry about a bandwidth difference — either is sufficient for uncompressed SD.
    [Joel Benedict] “It would be a good idea to buy it if I wanted to avoid something else I just thought of, which is the bandwidth cap of 4-conductor FireWire 400, but then again, the analog bandwidth cap of RCA stereo cables and S-video will be there regardless of the digital cap; FireWire probably has enough bandwidth to pass the signals through. “
    Video over FireWire is DV [link] — digital video compressed to 25 Mb/s, using a 720×480 raster, 4:2:0 chroma sub-sampling (NTSC), and an intraframe discrete cosine transform scheme.
    Contrast this with the Intensity, which can capture and save uncompressed video.
    Walter Soyka
  • Nick Brown
    December 5, 2013 at 11:15 pm
    I’ve always used the S-Video and RCA audio to digitize Hi8 because it is 4:2:2 video and holds up better when than using a DV converter that brings you into a 4:2:0 or 4:1:1 color space. Some graphics cards have a S-Video port but I use either a Matrox RTX, MX02 or if I want to filter out the interlaced artifacting, I use a Digital Rapid system to make the video better than the original Hi8. Then you can pick the level of compression and format that will give you better results than DV. Frequently I use a QT format or MPEG2 and sometime AVI depending on the scope of the project.
