Activity Forums Adobe After Effects Crisp Custom Layer Artwork in Element 3D
  • Crisp Custom Layer Artwork in Element 3D
    Posted by John Davies on October 18, 2012 at 10:50 am
    I need to create a 3D globe, preferably using Element 3D. I plan on rotating a camera round the Earth and then zoom to a certain city.
    I have imported and converted an Earth wrap vector to a shape layer and set this as a custom texture map in Element 3D. It looks great until I try zooming in. See attached image… GB Zoom
    I’ve scaled the shape layer which helped a bit but still can’t seem to find a method that will give me crisp lines that will allow me to focus right in on a specific area.
    I’ve tried variations of continuous rasterize, and different sizes but getting nowhere. Is there something I am missing? I’ve worked with shape layers plenty but never needed to zoom quite as much as this.
    Any help appreciated,
    John Davies replied 13 years, 5 months ago 3 Members · 3 Replies
  • Alex Udell
    October 18, 2012 at 3:02 pm
    I don’t know much about Element….
    But can you precomp the map source (in an oversized comp to prevent edge clipping)
    use the precomp as the map source in Element
    then keyframe the scale of the layer inside the precomp to match the timing of the move in on the element object in the main comp?
    a little tricky but should give a decent result I would think…..
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Mike Dunkin
    April 9, 2013 at 12:49 pm
    Did you ever get this resolved? I am having the same issue. Any precomp image seems to pixelate on a sphere.
    Mike
    Mike Dunkin
  • John Davies
    April 9, 2013 at 3:35 pm
    Sorry Mike, I struggled with this for too long and had deadlines looming, so I ended patching scenes together with a mix of C4D for the close-ups and Element for the wider, animated shots.
    Not easy or straight-forward, I just bodged it to get those scenes out of the way.
    If you find any alternative methods work out for you, let me know!
