Activity Forums Blackmagic Design Crestron DM – HDMI – HD-SDI | EDID Problem?
  • Crestron DM – HDMI – HD-SDI | EDID Problem?
    Posted by Nick Marques on March 12, 2012 at 12:58 am
    I have a Crestron DM-MD8X8 DigitalMedia sending 8G+ to a DM-RMC-100-C Receiver. The HDMI out on this is connected to a Blackmagic Design HDMI to HD-SDI converter to send video to a NewTek TriCaster 850 Extreme.
    The problem I have is two-fold. The biggest is that DMTool isn’t sending any video because it says either Invalid EDID or EDID N/A. I’m guessing this is because HD-SDI has no EDID? Is this a limitation of this inexpensive mini-converter?
    Assuming I can get this much to work, the 2nd problem is that apparently, the $39,000 TriCaster can’t automatically detect the input format it is being sent. So, because Crestron DM doesn’t scale unless you get a scaler room box, the TriCaster user would have to set the input format potentially each time a switch was made to the DM-RMC-100-C.
    I am thinking a scaling HDMI – YPrPb converter is my best bet. The Kramer VP-422 would do the trick. It does add 20ms of latency, but that may not be an issue. Other product suggestions are appreciated.
    I know this may be slightly off topic, but I think the BMD converter is the issue here. I know I can connect HDMI to any monitor and everything works.
    Nick Marques replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
