Activity Forums VEGAS Pro Credit rolls from Generated media has not enough space for adding long text info
  • Credit rolls from Generated media has not enough space for adding long text info
    Posted by Peter Popovici on July 9, 2010 at 3:33 pm
    Hello people! I tried to end a movie by using the credit rolls option from the Generated media. Big problem is that it does not allow you to add long credits, I mean big chunks of text – only 4-7 words approx. What to do to have my all long detailed credits added, please? Have a nice week end you all!
    Peter Popovici replied 16 years, 1 month ago 2 Members · 2 Replies
  • Joe Mantaratz
    July 9, 2010 at 3:51 pm
    You can add as many lines as you like and have the credits run forever. What you are probably doing is using the given template as is. Right click in space where the text would go and simply add another row. On the left hand side you can select what the format is for his new row whether that be a header, single, or two column format. Hope this helps.
  • Peter Popovici
    July 9, 2010 at 4:42 pm
    Thank you, JOE!
