Activity Forums Avid Media Composer credit roll jitter
  • credit roll jitter
    Posted by Rosy Rodrigues on September 30, 2005 at 2:44 pm
    Hhi ,
    I have a rather frustarting problem. i have created a credit roll in after effects which is then imported in avid for editing. My problem is that it jitters on air. i have tried Quicktme mov in the following formats:
    animation, avid meridien ( compressed and uncompressed) and they all cause some problem or the other. animation format ,jitters some time and at others it dosent.
    Can ayone tell me what’s wrong. do i need to have some other codec?
    Rosy.
    Carl Amoscato replied 20 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Carl Amoscato
    September 30, 2005 at 6:25 pm
    1. What size are the letters? Sometimes small text (or text with small details on it) will cause a roll to look jittery.
    2. Do you have the interlace order set correctly in AE and in Avid? If you’ve got it set wrong at any step of the process, it’ll screw everything up.
    good luck,
    Carl
  • Murlee
    October 1, 2005 at 9:24 pm
    Hi.
    Avid’s rolling titles always jitten on roll., esp on Xpress Pro machines. The best work aroud is to use Boris Grafitti or Marquee (HD)
  • Murlee
    Hi.
    Avid’s rolling titles always jitteR on roll., esp on Xpress Pro machines. The best work aroud is to use Boris Grafitti or Marquee (HD)
  • Murlee
    Hi.
    Avid’s rolling titles always jitteR on roll., esp on Xpress Pro machines. The best work around is to use Boris Grafitti or Marquee (HD)
  • Rosy Rodrigues
    October 3, 2005 at 9:44 am
    Avid’s rolling titles always jitteR on roll., esp on Xpress Pro machines. The best work around is to use Boris Grafitti or Marquee (HD)”
    sorry have no idea about these. are these softwares or codecs? and can i get them online? please elaborate.
    thanks,
    rosy.[murlee] “Hi.
  • Rosy Rodrigues
    October 3, 2005 at 9:53 am
    [Carl Amoscato] “1. What size are the letters? Sometimes small text (or text with small details on it) will cause a roll to look jittery.
    good luck,
    Carl”
    The letters sre not too fine. But u r right it cd be an interlace issue. will check on that..
    thanks
    rosy.
  • Carl Amoscato
    October 3, 2005 at 2:09 pm
    “Avid’s rolling titles always jitteR on roll., esp on Xpress Pro machines.”
    Wrong (all three times). If you learn to use the tool, you can make rolling titles that look just fine.
    Carl
