Activity Forums VEGAS Pro Credit roll
  • Credit roll
    Posted by Gary Badgley on June 9, 2012 at 2:54 pm
    Can’t seem to find the answer anywhere, and I’ve played with it too try to get it too slow down. I’m using timed fade in/out, but it will fade in or scroll in or whatever depending upon how I set the parameters. But the credits seem to only stay on the screen for just a second, far too short a time to hardly even read it. How do I slow it down?
    Thanks in Advance.
    Edward Troxel replied 14 years, 3 months ago 2 Members · 2 Replies
  • Gary Badgley
    June 9, 2012 at 10:20 pm
    I finally found the answer. Click on the credit roll event and then click on properties. There is a playback field that you can adjust.
  • Edward Troxel
    June 11, 2012 at 1:27 pm
    Just hold down the CTRL key and adjust it to the length you want it to be. That does the same thing as adjusting the “Playback rate” but also the length of the event will match the new playback rate.
    Edward Troxel
    JETDV Scripts
