Activity › Forums › Apple Final Cut Pro Legacy › credit crawl
credit crawl
Posted by Jeremy Presner on April 23, 2008 at 2:32 amI’m wondering if there’s a way, within FinalCutPro to do a Tail – credit crawl, 2 columns, the first column right justified, the 2nd column left justified so that they appear like they do in most films; the way it is now i can only have it centered. Do i need to create 2 seperate crawls on seperate video layers in order to create this?
Jeremy Presner
http://www.presner.com
Editor Film/TVJeremy Presner replied 18 years, 5 months ago 5 Members · 9 Replies -
Walter Biscardi
April 23, 2008 at 2:43 amWe use Title 3D for this and create two titles to run side by side. The left crawl is right justified, the right crawl is left justified. Just line them up and they run up perfectly.
Or create two layers in Photoshop and crawl those up.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Herb Sevush
April 23, 2008 at 3:51 amCHV makes a set of text plugins that contains a credits plugin that will do exactly what you want. I use it all the time. Costs $49.
Herb Sevush
Zebra Productions -
Dzul Sungit
April 23, 2008 at 7:06 amHi Jeremy,
If you want to achieve a film scroll style using scrolling text, insert an asterisk (*) after or before every text segment to indicate the gap. For example: Online Editor*Jeremy Presner. You can adjust the amount of space between the text by changing the “gap width” value.
Hope this helps.
Warmest greetings to all the great contributors on this forum – you’ve helped me many times in the past! 🙂
Dzul
Jeremy Presner
April 23, 2008 at 11:59 amThanks very much for all your for your help, especially Dzul Sungit who came up with a solution that worked out the best for me!!
Jeremy Presner
Editor Film/TV -
Jeremy Presner
April 23, 2008 at 12:50 pmThe credit crawl does not run smoothly, it kind of warbles every few frames any way to make it smoother?
Jeremy Presner
Editor Film/TV -
Walter Biscardi
April 23, 2008 at 1:42 pmBe sure to activate the 1:2:1 deflicker (or something like that) in the Boris Crawl.
Read my Blog!
Jeremy Presner
April 23, 2008 at 6:50 pmI am not using the Boris text, I am using FinalCutPro’s built in “scrolling text” which doesn’t seem to have that option listed! Just options like indent, spacing, gap width, fade size, direction, auto kerning…
Jeremy Presner
Editor Film/TV -
Arnie Schlissel
April 23, 2008 at 8:03 pmYou should use the Boris Title Crawl instead of the old FCP generator. It will give you the 1:2:1 deflicker, more control over the text, and a cleaner result all around. Instead of an asterisk, you can use tabs to create the columns.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Jeremy Presner
April 24, 2008 at 8:21 pmI tried using the tabs in Boris, but they do not align properly, I need the left column to be right justified and the right column to be left justified.. any advice?
Jeremy Presner
Editor Film/TV
