Activity › Forums › Avid Media Composer › Credit crawl disappears when rendered????
  • Credit crawl disappears when rendered????
    Posted by Alan Howard on July 8, 2013 at 9:38 am
    I have a credit crawl, generated in Avid FX which appears or disappears depending on what the video quality setting is set to … and this is not just when playing, this is also when the playback is paused…When yellow (low res) I can see the whole crawl albeit fuzzy low res, when yellow/green I can see the crawl from about 30 characters in, when fully green I can see from approx 80 characters in …. I’d assumed this was a render issue so rendered that section but the render is exactly the same, I’ve tried exporting that section, and the same thing happens .. the crawl starts about 80 characters in ???
    Any clues ??
    I’m up against a looming deadline.. any help appreciated !
    Thanks in anticipation …
    Alan
    Alan Howard replied 13 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
