Activity Forums Adobe After Effects Expressions creative random flickers
  • creative random flickers
    Posted by Adam Chen on February 3, 2012 at 1:34 pm
    I want to craeative some random flickers,and I can control the flash speed.
    so I write this Expression,
    position:
    tot = linear(time,0,4,1.5,8);
    r = random(-4,1);
    c = clamp(r,0,1);
    wiggle(tot,700*c)
    brightness:
    len = length(effect(“Optical Flares”)(“Position XY”),effect(“Optical Flares”)(“Center Position”));
    k = random(0.8,1.4);
    if(len>100) {
    120*k;
    }else{
    0
    It can work but not so perfect,cause it`s position bases on random wiggle.and falsh speed also hard to control.
    Did you have any better ideas?
    Adam Chen replied 14 years, 7 months ago 2 Members · 2 Replies
  • Immanuel Morales
    February 12, 2012 at 4:44 pm
    I always end up telling people the same thing when it comes to controlling expressions: use the expression controls in the effects and presets and plug your variables into that. so for instance..
    speed = thisComp.layer("whichever layers you'll use").effect("Slider Control")("Slider");
    amplitude = thisComp.layer("same layer as above").effect("Slider Control 2")("Slider");
    tot = linear(time, 0, 4, 1.5, 8);
    r = random(speed, amplitude);
    c = clamp(r, 0, 1);
    wiggle(tot, 700*c)
  • Adam Chen
    February 15, 2012 at 7:00 am
    Thanks for you reply,I will try it.
