Activity › Forums › Adobe After Effects › Creative framing of 4:3 insert window
  • Creative framing of 4:3 insert window
    Posted by Andy Stokes on January 9, 2006 at 10:59 am
    Hi all,
    Need to simply insert some 4:3 material onto a flat gfx bg.. Designers block really has kicked in, big time.. I can’t come up with any “creative” way of masking footage onto a bg without it looking exactly like a cheesy DVE effect.
    Any ideas ?? Come on, someone humour me….
    Cheers,
    Andy
    p.s: Hopefully tomorrow will bring a solution… Call myself a designer ??
    Andy Stokes replied 20 years, 8 months ago 2 Members · 2 Replies
  • Chris Smith
    January 9, 2006 at 4:29 pm
    -Mask it into slight ovals:
    -Make it larger and break it up into pieces. So it looks like a bunch of smaller 4×3 panels made a larger video wall. (do this by making a grid pattern, precomping the grid and using it as a luma matte on the video layer).
    – Parent all the images to a null then make them all face outward from the null in a circle. So when you rotate the null it looks like a disc with images is spinning. Then animate them spin like a slot machine and lock into place at times to show the image.
    – Use orhanic mask shapes with hevay feathering to look like amorphious blobs.
    – Set the images up in space. And create angled spotlghts that search across them like a police search light revealing them one at a time.
    – Use vertical stripes of different thickness overlapping each other. These stripes also reveal the images like slowly moving vertical blinds.
    – Use the subject matter to justify the movements. If it’s about gambling, make a slot machine effect or map the images to playing cards. If it was about nature, the images can be amongst a forest or mapped onto leaves, etc.
    Just brainstorming.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Andy Stokes
    January 9, 2006 at 6:17 pm
    Hi Chris,
    Appreciate you taking the time to reply with your brainstorming. Some good ideas…
    Here’s hoping tomorrow everything will fall into place… Hey there’s another idea.
    Cheers,
    Andy
