Activity Forums Apple Final Cut Pro Legacy Creative Cow “VIDEOS-REELS” Upload Failure?
  • Creative Cow “VIDEOS-REELS” Upload Failure?
    Posted by Daniel Monskey on March 18, 2011 at 9:37 pm
    I have been attempting to upload a short video to the Creative Cow “VIDEOS – REELS” page and failed with every attempt and every format. It is a 960 x 720 59.94 fps 3:29 minute video. I am outputing through FCP 7.0.3 using Quicktime Conversion. I set it to the H.264 setting and I’ve gotten it to a manageable size (less than 500MB—455MB). After a few hours of “loading” a message comes back “No file found in upload”. I have output this same file using “Program Stream.mpeg” (408MB), which I thought was an acceptible format.
    Any suggestions to get this video to successfully upload? I had this same problem months ago and finally gave up. I attempted more format variations at that time and failed with all, so I am loosing faith with failure coming so regular. I would really like to post this and get feedback from the CC community.
    Dan
    Daniel Monskey
    Daniel Monskey replied 15 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Stephen Smith
    March 18, 2011 at 10:10 pm
    There is a demo reel forum that is the place to post this question: https://forums.creativecow.net/demoreels
    500mb sounds really big to me. How long is this video?
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Daniel Monskey
    March 18, 2011 at 10:31 pm
    It may seem big, but the VIDEOS/REELS pages says tha tis the max acceptible size. It is a 3:29 minute piece. It doesn’t have “.H.264” as an ending, but the format is in that form. The other does have the “.mpeg” in the title.
    Dan
    Daniel Monskey
  • Daniel Monskey
    March 18, 2011 at 10:33 pm
    I did not see the “Demo-reels” forum. Overwhelmed by the variety. I posted there now.
    Thanks for the suggestion and help.
    Dan
    Daniel Monskey
  • Rafael Amador
    March 18, 2011 at 10:36 pm
    [Daniel Monskey] “3:29 minute video.”
    Hi Daniel,
    500 MB for a 3′ 29″ video clip is simply CRAZY.
    That data-rate is huge for any H264 or MPEG-2.
    Which data rate are you setting?
    Which K-frames are you setting?
    rafael
    http://www.nagavideo.com
  • Daniel Monskey
    March 18, 2011 at 11:41 pm
    From FCP I “export using QT Conversion”
    Leave the setting at QT Movie
    Compression Setting is: H.264
    Compressor quality is at “Medium”
    Key Frames is; Every “24” frames
    Encoding: Best quality (multi-pass)
    The Dimensions are set to 1280×720 (1248×702)
    Audio is Integer 48.000kHz 16 Bit Stereo
    “Prepare for internet Streaming (Fast Start)”
    On a 3′ 29″ video it compresses an output file of 455.1MB.
    That is the settings. I always try to maximize my quality since I hate the pixelating at lower quality.
    Perhaps I need a lesson on output procedures.
    Dan
    Daniel Monskey
  • Rafael Amador
    March 18, 2011 at 11:59 pm
    [Daniel Monskey] “From FCP I “export using QT Conversion”
    OK.
    Move the Quality Slide to High and set:
    – Key-frames: AUTO.
    – Data-rate: “Restricted to: 12.000 kbps”.
    – Set the audio to AAC (256Kbps) instead of PCM.
    Export and your movie will look great and much lighter.
    rafael
  • Daniel Monskey
    March 19, 2011 at 12:25 am
    Wow Rafael—Thanks for the help!
    How can I learn how to make all the different settings and adjustments and which compressions to make? If I don’t do this all day every day it seems like a lot to learn for the varying needs and uses. What would be the most helpful source from which to learn?
    Dan
    Daniel Monskey
