Activity › Forums › DVD Authoring › creation resolution
  • creation resolution
    Posted by Brian Cooney on April 8, 2009 at 12:05 am
    I know this is a DVD creation forum but what do you all suggest is the best or most common resolution to create HD work in for DVD playback..either in FCP or Motion. I have typically done Broadcast SD 720×480 for 480i.
    Is 1920×1080 always the best in every case? That is the norm for 1080p hey? so even if you are in 1080i or 720p 1920×1080 will do all the best?
    any comments? thanks…
    Michael Sacci replied 17 years, 5 months ago 2 Members · 7 Replies
  • 7 Replies
  • Michael Sacci
    April 8, 2009 at 12:12 am
    Are you talking BluRay DVD? SD DVD? What is your source material?
  • Brian Cooney
    April 8, 2009 at 12:14 am
    thanks. it would be HDV for DVD..
  • Michael Sacci
    April 8, 2009 at 12:17 am
    Whatever your footage is, keep it at that, including progressive or interlace.
  • Brian Cooney
    April 8, 2009 at 12:21 am
    cool thanks… what if you are working with graphic based stuff in motion. no capture. what do you typically default to for a project… HDV 720p60, DVCPRO HD 720p/30 or 60 or DVCPRO HD 1080p30?
  • Michael Sacci
    April 8, 2009 at 12:35 am
    Total graphic, like a menu, not going to be integrated with any video, I would probably use 720p, easier on the system there probably would be a noticeable difference when downconverted to SD. It would cross-convert to 1080i okay if you need to put it with your footage down the road. But there is not a real right or wrong answer here.
  • Brian Cooney
    April 8, 2009 at 12:42 am
    that seems like very sound advice though. i’ll run with it. thanks man
  • Michael Sacci
    April 8, 2009 at 3:24 am
    DV I/O to camera or FCP.
    Camera in VTR mode, not on THumbnail mode > play clip on the FS hit Red REcord and Gray button on by the handle.
    FCP Log and Capture > play clip on FS hit Capture Now in FCP.
