Activity Forums Adobe After Effects Creating/duplicating compositions independently
  • Creating/duplicating compositions independently
    Posted by Ryan Hillaby on September 6, 2016 at 6:31 pm
    Hello,
    Im trying to figure out what the best/easiest way is to duplicate my comps/precomps to be independent comps.
    To explain my situation, basically im creating hockey player cards. Not like the trading cards, but when you go to a hockey game and a player scores, its a short 10 second animation where the logo comes up with footage of the player and their name. I have a base file or composition finalized to work off of…but i need to duplicate that about 30-40 times for this whole roster of players so that i can do 2 for each player.
    The problem im running into is that the composition that im trying to duplicate has a bunch of precomps inside (comps inside of comps inside of comps, etc…) so whenever i try to edit it it ends up messing with the base file.
    I need a quick/easy way to duplicate the composition including everything inside so that every element is independent.
    Thanks in advance for any help!
    Lorin Crosby replied 10 years ago 4 Members · 4 Replies
  • Roei Tzoref
    September 6, 2016 at 7:31 pm
    you can re-import your project and you will have independent comps. and you can use this script – True Comp Duplicator script here: https://aescripts.com/true-comp-duplicator/
  • Roei Tzoref
    September 6, 2016 at 7:37 pm
    very happy to assist you Mr. LeRonde 🙂
  • Eric Santiago
    September 6, 2016 at 7:50 pm
    [Roei Tzoref] “you can re-import your project and you will have independent comps. “
    This was my fave for years.
    I will try that script you posted thanks!
  • Lorin Crosby
    September 14, 2016 at 6:52 pm
    Hi, I just got true comp dup. but it isn’t duplicating the expressions. I had “update expressions” checked
    I am using the latest version of true comp
    please help
