Activity › Forums › Apple Final Cut Pro Legacy › Creating workflow for feature length documentary
  • Creating workflow for feature length documentary
    Posted by Scott Busch on January 4, 2010 at 8:45 am
    I just got on board a feature length documentary and it’s my very first one. I’m trying to figure out the best workflow for the project.
    When I first came on board they only had 9 hours of footage shot (and still do) from a Sony V1U @ 1080i 24p.
    I figured out the best workflow by capturing the HDV footage as Pro Res 422, but I am starting to worry that this workflow isn’t going to work throughout the film process. I’m afraid that it is going to take up way too much disk space. I’m not sure if it’s necessary to capture everything with an online codec like pro res 422.
    By the end, we will have over 200 hours of footage. 200 hours of Pro Res footage = 13 TBs
    What is the best HD workflow when dealing with this vast amount of HDV footage?
    Should I be downresing this stuff in order conserve space?
    What type of hard drive setup should I be using?
    If I do need to capture the hundreds of hours of footage at a lower quality, what would we be the best workflow to allow us to recapture the finished project back into Pro Res for the online edit?
    Scott Busch replied 16 years, 8 months ago 4 Members · 6 Replies
  • David Roth weiss
    January 4, 2010 at 12:02 pm
    Just capture and cut as hdv, and when you’re done just change the compressor in Sequence>>Settings to ProRes and re-render. Bingo, your entire seq is now ProRes, and exporting a QT movie at current settings produces a ProRes file identical to the timeline in every way.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Steve Eisen
    January 4, 2010 at 3:15 pm
    You can do what David says or spend some cash on a new RAID (RAID 5 is what I would suggest). If you are dealing with this much footage, you must be charging enough to edit this doc (I hope). I’ve seen 2 TB HD’s between $130-$150. Invest now or pay later.
    Did you learn anything from your previous job?
    https://forums.creativecow.net/thread/27/858383#858383
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • David Bogie
    January 4, 2010 at 4:40 pm
    David,
    You’re suggesting working in HDV live and depending on the Macintosh to process it in realtime?
    I’m not going to suggest that’s not a good workflow, I don’t really know, never shot HDV (never want to) but I’ve been reading for several years that HDV should get converted to something more directly editable. Have I been reading all of those posts incorrectly? (Quite likely, I have zero experience with HDV so I could have been easily confused. That happens to me a lot these days.)
    I do have a couple o’three suggestions for the OP.
    Working with huge amounts of footage is nothing new. Documentary workflows are not secrets and there’s no reason to reinvent anything. Spend a few hours on Google and you should come across dozens of suggestions for managing your huge volume of documentary material. However, just because you have 200 hours of material doesn’t mean you have to capture and store all of it and remember what all of it looks like.
    In the olden days, we’d burn timecode window copies to VHS and spend a few days working on a paper cut, deciding what’s crucial, what’s worth keeping for b-roll, and what we can easily file away as c- or d-roll.
    Your camera tapes are precious. Be sure the producers have them carefully stored. Might want to make backup dubs of them.
    Decide early on file naming conventions. Never use any of these terms in your filenaming: latest, final, best, current, new.
    At every important juncture of the production process, increment your project version.
    Be sure you understand how the autosave vault works.
    Be sure you understand in your contract who is responsible for creating and maintaining backups of your project and exactly what the term “backup” means.
    bogiesan
  • David Roth weiss
    January 4, 2010 at 6:34 pm
    [david bogie] “David,
    I’m not going to suggest that’s not a good workflow, I don’t really know, never shot HDV (never want to) but I’ve been reading for several years that HDV should get converted to something more directly editable. Have I been reading all of those posts incorrectly? (Quite likely, I have zero experience with HDV so I could have been easily confused. That happens to me a lot these days.) “
    Hey Bogie,
    You’re absolutely right, the first choice for those of us, “in the know,” who work with HDV, would be to capture to an iframe codec before editing. However, without a Kona or BM card, and when doing a really big job that is estimated to be 13Tb of ProRes from the start, vs a mere fraction of that with HDV, is simply better off editing the HDV. HDV isn’t the best editing format, but it’s not really a deal breaker if have to bite the bullet.
    David Roth Weiss
    Los Angeles
  • David Bogie
    January 4, 2010 at 8:38 pm
    [David Roth Weiss] “You’re absolutely right, the first choice for those of us, “in the know,” who work with HDV, would be to capture to an iframe codec before editing. However, without a Kona or BM card, “
    Ah, I missed or skipped over any references to possible hardware support. That would make a huge difference, yes.
    Thanks for the help on this point, David.
    bogiesan
  • Scott Busch
    January 6, 2010 at 8:45 am
    Alright, thanks guys for all the posts! This definitely clears some things up for me.
