Activity Forums Adobe After Effects Creating webcam effect with frame rates
  • Creating webcam effect with frame rates
    Posted by Adhish Yajnik on August 2, 2011 at 9:09 pm
    I have a piece of footage shot at 23.976 fps that I need to comp into another 23.976 fps shot of a TV screen. The footage that’s going in the screen is supposed to look like it’s from a webcam, and I want to lower the frame rate to about 15fps to make it a little jittery as part of the webcam look, but still render the final shot out to 23.976 fps.
    I tried nesting the webcam footage in its own comp, with a comp frame rate of 15, but when I play back the final shot at 23.976, the webcam shot loses that jittery quality.
    Any ideas?
    Walter Soyka replied 15 years, 1 month ago 4 Members · 6 Replies
  • Adhish Yajnik
    August 3, 2011 at 1:54 am
    Worked like a charm! Thanks!
  • Patrick Smith
    August 3, 2011 at 1:39 pm
    This is a really easy effect to achieve. Just go to your effect panel and search for an effect called “Posterize time”. It does not effect the frame rate your project frame rate, all you have to do is adjust your desired frame rate in the effect controls. I used this effect a few times to make my footage look like it was from an old film camera. The results were great!
  • Walter Soyka
    August 3, 2011 at 3:03 pm
    Bonus webcam grunge effects: consider desaturating a little with the Hue/Saturation effect [link], oversharpening with Sharpen [link] or Unsharp Mask [link], and occasionally macroblocking a bit by layering on some Mosaic [link] (optionally limited by a track matte [link]).
    Walter Soyka
  • Patrick Smith
    August 3, 2011 at 11:45 pm
    This is a really easy effect to achieve. Just go to your effect panel and search for an effect called “Posterize time”. It does not effect the frame rate at all. You just
  • Todd Kopriva
    August 4, 2011 at 3:56 am
    The Posterize Time effect does work for this, but here’s a tip for a higher-performance way of doing it:
    Nest the composition in a composition with a lower frame rate.
    Why?
    The method with Posterize Time still calculates every frame and then throws several away. The method with with nesting just calculates the necessary frames.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Walter Soyka
    August 4, 2011 at 2:26 pm
    [Todd Kopriva] “The Posterize Time effect does work for this, but here’s a tip for a higher-performance way of doing it: Nest the composition in a composition with a lower frame rate.”
    To use this method, I think you must also enable Composition > Composition Settings > Advanced > Preserve frame rate when nested or in render queue in the comp with the lower frame rate.
    If that option is not checked, the precomp will inherit the frame rate from the containing comp.
    Walter Soyka
