Activity Forums Adobe After Effects Creating Visible Smells
  • Creating Visible Smells
    Posted by Jesse Jacobson on April 20, 2017 at 6:05 am
    Hey guys need some advice
    Im making this post across 3ds max, C4d and After effects as i dont know which program to use for this in case one is better.
    I need to create a visual representation of smells (for instance seeing a fart)
    They need to be able to be manipulated as if being blown away with a hand.
    What technique would be the best to create this and would After Effects be better than the other 2 stated above.
    Thanks guys just a general question any feedback would help ????
    cheers
    Dirk De jong replied 9 years, 5 months ago 2 Members · 1 Reply
  • Dirk De jong
    April 20, 2017 at 12:17 pm
    My first inclination would be to use particles (even if they end up post processed so they don’t necessarily look like particles in the final result). But I suspect the particles that come standard with AE are perhaps not feature rich enough to pull it off well so probably (in AE at least) I would use a 3rd party AE plugin particle effect.
