Activity Forums Maxon Cinema 4D Creating Visible Smells
  • Creating Visible Smells
    Posted by Jesse Jacobson on April 20, 2017 at 6:05 am
    Hey guys need some advice
    Im making this post across 3ds max, C4d and After effects as i dont know which program to use for this in case one is better.
    I need to create a visual representation of smells (for instance seeing a fart)
    They need to be able to be manipulated as if being blown away with a hand.
    What technique would be the best to create this and would C4d be better than the other 2 stated above.
    Thanks guys just a general question any feedback would help ????
    cheers
    Jesse Jacobson replied 9 years, 4 months ago 3 Members · 5 Replies
  • Corrado Carlevaro
    April 20, 2017 at 9:44 am
    I’d use Trapcode Particular plugin in After Effects but if you don’t own that plugin I believe it to be very complicated with AE tools alone. With Particular I’d use a “cloudy” sprite as particle, then I’d move the flux of particles along a Path and then a combination of Wind or Spherical Field to blow the particles away.
    With C4D I’d use Thinking Particles
    Corrado
  • Adam Trachtenberg
    April 20, 2017 at 5:08 pm
    This is a gas/fluid simulation so the best thing to use would be a purpose-built simulator like the TurbulenceFD plugin for Cinema. X-Particles could also do a pretty good job with or without fluid simulation. The next best option in Cinema would be Thinking Particles with Pyrocluster. Can’t speak to 3dsmax, though, as I haven’t used it in years.
  • Jesse Jacobson
    April 23, 2017 at 6:28 am
    Hey adam
    Just had a question about turbulence or x particles.
    i have a scene where the person need to push the particles/smoke/smells away with his hands or blow then away.
    is there any way to do that with either of these tools.
    and if so could you recommend a method or maybe a video.
    cheers
    jesse
  • Adam Trachtenberg
    April 23, 2017 at 3:15 pm
    Hi Jesse,
    Yes, both TFD and xParticles provide for dynamics/collision. Here’s a quick example I did with TFD: https://www.3danvil.com/temp/Fart_.mov
  • Jesse Jacobson
    April 25, 2017 at 2:47 am
    Thanks Adam
    Thats exactly what im looking for ill just stick with TFD this is a great help
