Activity › Forums › Adobe Premiere Pro › Creating video using image frames
  • Creating video using image frames
    Posted by Aileen Chen on May 15, 2008 at 1:59 am
    Hi all,
    I have Adobe Premier Pro 2.0, and I was wondering if there’s an easy way of creating a video using a sequence of frames (in an image format). Right now I can do it by importing each frame, manually changing the speed/duration for each frame, and then piecing them together. Is there a faster way to do this? If not, is there a way to change all the frames’ speed/duration at once? Thanks!
    Jon Barrie replied 18 years, 4 months ago 2 Members · 1 Reply
  • Jon Barrie
    May 15, 2008 at 7:46 am
    Are you talking about image sequences? where the name and #### number follow on like a string of images that make a video. That is supported by ticking the image sequence box when importing the 1st image. It will then come into PPro as a single clip. And can be treated as such.. slow motion (speed/duration) etc.
    – Jon 🙂
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
