Activity › Forums › Adobe After Effects › Creating Video Glitches
Posted by Ryan Dent on February 12, 2008 at 11:04 pmHow would I go about creating video glitches almost like in the Cloverfield movie and what would be the easiest way?
I.a. B. replied 18 years, 6 months ago 3 Members · 4 Replies -
I.a. B.
February 13, 2008 at 2:09 ami have strived to learn how to do this and now i can tell you. one way to do this, is a displacement map, i made an animation using some photos from this site https://www.karlklomp.nl/mda/still.html of those real glitches, then you put the animation in your comp, use it as a displacement map and ta da you’ve got some messed up footage.
another way (something that i did) is to create animated elements that you can lay ontop of the footage and set to a transfer mode to imitate some things, i’ve got one that makes some purpleish distortion like recording on the lead of a DV tape, another that is some random bars of noise and scan lines, and a few others, all built using fractal noise, and a few other effects ontop of it.
another good trick is to capture some footage from an OLD VCR into the computer, but you probably have to go analog, right up to the capture, or you’ll just get a blue screen.
if there’s anyway i can send you the pre sets, i will.
EDIT: here’s a pic of one of the pre sets i made to look like part of the “cloverfield” logo in the trailer.
https://img222.imageshack.us/img222/3826/picture28kz2.png
Ryan Dent
February 13, 2008 at 4:24 amthanks a ton! the displacement map technique actually worked better than i expected. but if you could send me those presets that would be great! thanks!
Jiri Fiala
February 13, 2008 at 9:28 pmMe too please :o) Or if you could post it somewhere on the netm that would be great. Thanks!
I.a. B.
February 16, 2008 at 4:08 amhere’s a link to a video showing some of the presets https://www.vimeo.com/695298
