Activity Forums Live Events & Streaming creating video content for 12 screen video wall
  • creating video content for 12 screen video wall
    Posted by Bang Tran on December 12, 2012 at 5:32 pm
    Hello all,
    I am working on creating video for a video wall that is 12 screens wide and in portrait. The resolution is 1920 * 1296 per screen and 1920 * 12960 for the entire video wall. The player is a Web DT MS1800 with 12 outputs. My first question is can I do this in Premire pro cs5 or after effects cs5? Does anyone know how I can create the video in the full 1920*12960 than break it down to 1920*1296 so the video will be in 12 independent videos to make the file size smaller. I don’t think my computer is powerfull enought to handle the 1920*12960 resolution. Thank you very much.
    Bang
    Bang Tran replied 13 years, 8 months ago 2 Members · 2 Replies
  • Walter Soyka
    December 12, 2012 at 5:51 pm
    The maximum comp size in After Effects is 30,000×30,000 px. The maximum sequence size in Premiere Pro is 10,240×8,192 px.
    I assume you mean 1920×1080 per output.
    You can work at the full 12,960×1920 in Ae and render out to a set of twelve 1080×1920 outputs, either by nesting your main composition into a smaller portrait HD comp and repositioning for each display, or by setting up a series of output modules with different crops for each display.
    If you intend for this to behave like one seamless canvas, there is no good way to split up a comp like this into smaller screens. You can, however, work in lower resolutions or with proxy media with Ae.
    I do a lot of large-format work like this, and I’ve written a lot of posts in the After Effects forum here about improving performance with Ae — a quick search there should turn up some results for you.
    What are your system specs? A project like this really needs a lot of system resources, so an upgrade might be in order.
    Walter Soyka
  • Bang Tran
    December 12, 2012 at 6:13 pm
    Thank you for the quick reply Walter.
    I am running windows 7 64bit with intel Xeon 2.8 GHz 4gb of ram
    NVIDIA GeForce GTX 570
    When you say work in lower res or poxy media I got lost. Sorry I’m new to this, can you explain a little more on this?
