Activity › Forums › Adobe After Effects Expressions › Creating Value Parameters when an effect is Pickwhipped to the parameters on a adjustment layer with sound keys
  • Creating Value Parameters when an effect is Pickwhipped to the parameters on a adjustment layer with sound keys
    Posted by Richard Altman on May 17, 2012 at 12:19 am
    here’s my situation:
    i have placed sound keys on an adjustment layer
    on another adjustment layer [adjustment layer 2 in this case] i have a photograph underneath it
    on adjustment layer 2 i have placed the mirror effect, what i’d like to do is create parameters so that the reflection angle is either 270 or 90, while pickwhipped to the Output 3 layer of the adjustment layer that has sound keys.
    so i’m just curious regarding how to establish parameters in this case of only two values yet those two values are triggered via the keyframes from the sound keys imbued adjustment layer.
    hopefully that makes sense,
    thanks in advance
    Rich
    adjustment layer 2
    thisComp.layer("Adjustment Layer 1").effect("Sound Keys")("Output 3")
    Richard Altman replied 14 years, 4 months ago 2 Members · 5 Replies
  • Dan Ebberts
    May 17, 2012 at 2:25 am
    From what you’re describing, I think it will look like this:
    sk3 = thisComp.layer(“Adjustment Layer 1”).effect(“Sound Keys”)(“Output 3”);
    triggerLevel = 10;
    if (sk3 > triggerLevel) 270 else 90
    You’ll need to adjust triggerLevel to something that makes sense for your keyframe range (and you might have to swap the 270 and 90).
    Dan
  • Richard Altman
    May 17, 2012 at 2:48 am
    Thanks for the response Dan, I have yet to try what you suggested, I will in a few hours, I’m just at work, however, does the screen shot essentially describe how I should word what you mean?
    ill be honest i don’t quite get how to successfully embed the screenshot into this post.
    thanks for your patience
  • Dan Ebberts
    May 17, 2012 at 2:55 am
    I’m sorry–what screen shot are you talking about?
    Dan
  • Richard Altman
    May 17, 2012 at 3:48 am
    yeah i tried, i don’t see how to include the screen shot,
    i think i got it now, little tired today
  • Richard Altman
    May 17, 2012 at 4:43 am
    Thanks Dan, it completely worked and I believe I honestly learned some important things about expression grammer, or how to properly express, expressions.
    thanks again
