Activity › Forums › VEGAS Pro › Creating title problem
  • Creating title problem
    Posted by Jeremiah Fleming on November 30, 2009 at 9:40 pm
    hello all,
    Why is it everytime I go to create a title the box where I type the title text in keeps disappearing and going behind everything and i cant find it?? Please advise ASAP I am working on a project,,
    Mike Glynn replied 16 years, 7 months ago 5 Members · 9 Replies
  • 9 Replies
  • Theo Van laar
    November 30, 2009 at 10:39 pm
    OK, I will try to type very fast…
    When you drag wirh the window where you type the text, this window will try to tab itself with all the other tabs. To avoid this, you can press the Ctrl button when you drag a window (this was 7 seconds…)
    Theo
  • Jeremiah Fleming
    November 30, 2009 at 11:46 pm
    This does not help.. What I am doing is trying to create text and when I click on GENERATED MEDIA the box disappears. Please advise
  • Theo Van laar
    December 1, 2009 at 12:03 am
    Which box disappears?
    Theo
  • Jeremiah Fleming
    December 1, 2009 at 12:25 am
    The text box where you type text disappear behind everything
  • Jeremiah Fleming
    December 1, 2009 at 12:32 am
    The Video Event Fx box goes away and i cant not see it. Its like a pop up blocker is stopping it from opening.
  • Stephen Mann
    December 1, 2009 at 5:14 am
    Click on view and make sure it’s selected. Can you post a screen shot of what you’re seeing? I can’t picture it in my mind.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Theo Van laar
    December 1, 2009 at 12:14 pm
    ‘The text box where you type text disappear behind everything’
    Is it moving to the tabs? Or where exactly is it moving to?
    Theo
  • John Rofrano
    December 1, 2009 at 5:55 pm
    It might be that it got placed off screen somewhere. You can try resetting your windows layouts with View | Windows Layouts | Default Layout.
    You can also reset all of Vegas by holding the SHIFT key when you launch it. This will reset all of your preferences so this should only be used as a last resort.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Glynn
    February 5, 2010 at 3:45 am
    I am using the trial version SV plat pro 9.0b. I have used previous versions of Sony Vegas and love the product (have been using since 2002). I was planning to upgrade, but I am struggling with the text generator… I am able to see the “Video Media Generator”, but no where can I “enter” text, “edit” text, “format” text or any manipulation of any kind. Are there utilities that I should be using? Is the trial version limited? (I am using Vista Home, 32 bit). The edit text works fine on my Sony Vegas 4.0. Any thoughts?
    Mike
