Activity Forums VEGAS Pro Creating Title Builds in Vegas pro 11
  • Creating Title Builds in Vegas pro 11
    Posted by Bruce Miller on June 5, 2012 at 7:15 pm
    So, now that I have 4 titlers with Vegas Pro 11, I still can’t make a simple PowerPoint style build without effort.
    For a 4-line title build, my approach is to
    1. create a 4-line title using the legacy titler
    2. Copy the title frame 3 times on the timeline
    3. Delete successive lines in each event to create a build.
    4. Adjust placements on the timeline
    Placement cannot be “Freeform” and I have no idea how to add a bullet character.
    Given all the firepower of the other titlers, is there a better way? I tried New Blue and it was ultimately way more cumbersome. Suggestions appreciated.
    Bruce M
    John Rofrano replied 14 years, 3 months ago 3 Members · 4 Replies
  • John Rofrano
    June 6, 2012 at 2:05 am
    [Bruce Miller] “Given all the firepower of the other titlers, is there a better way? I tried New Blue and it was ultimately way more cumbersome. Suggestions appreciated.”
    The easiest way is to get Boris Graffiti (or RED) and apply the Animated Bullet Points preset and you’re done. The Boris Graffiti titler is probably the most powerful titler out there for Vegas Pro.
    You can also do this with the Sony ProType Titler that’s built right into Vegas Pro. I have a video tutorial on Youtube that shows you how to cascade text which should give you the information you need to make bullets appear in order:
    Sony Vegas Pro ProType Titler Cascading Highlight Text Tutorial
    Just have them cascade a bit slower.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Edward Troxel
    June 6, 2012 at 3:15 pm
    Titler Pro will also let you transition in individual lines over time.
    Edward Troxel
    JETDV Scripts
  • Bruce Miller
    June 6, 2012 at 3:30 pm
    Thanks for turning me on to Graffiti — which I plan to get and learn. The key to this will be whether the bullet events can be easily positioned with the soundtrack.
  • John Rofrano
    June 6, 2012 at 6:32 pm
    [Bruce Miller] “The key to this will be whether the bullet events can be easily positioned with the soundtrack.”
    You can import the sound track into Graffiti to do the positioning and then mute it (or delete it) when you’re done.
    ~jr
