Activity Forums Adobe Premiere Pro Creating time-lapse from stills
  • Creating time-lapse from stills
    Posted by Sheree Day on June 2, 2015 at 8:53 am
    Hi
    I have a large amount of photos (500+) that I need to put together to create a time-lapse movie.
    Is it possible to do it in Premier Pro CS6 to make it look realistic? Or AE CS6?
    Thanks in advance.
    James Strawn replied 10 years, 11 months ago 3 Members · 2 Replies
  • Joe Barta iv
    June 2, 2015 at 1:04 pm
    In Premiere, under Preferences, change the Still Image Default Duration to 1 frame. Then import your images. If they are numbered sequentially, you should be able to select them all and drag them right onto a timeline.
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • James Strawn
    June 2, 2015 at 10:44 pm
    Another option is to import all files as an image sequence so that they will be treated as a single clip in PrPro. But I actually prefer Joe’s method because you have separate control over each and every frame if needed. It can still sort of be treated as a clip that way if you put them all inside a nested sequence.
    Software Quality Assurance – Digital Video at Adobe Systems
