Activity › Forums › Avid Media Composer › creating texture on Avid titles……
  • creating texture on Avid titles……
    Posted by Paul Harb on March 20, 2006 at 7:02 pm
    I want to create a weathered look on my titles using an Avid Adrenaline……Im sure there is an easy way to do this without going outside the program, anyone?
    Paul
    Dave Schweitzer replied 20 years, 6 months ago 3 Members · 2 Replies
  • Joe Womble
    March 21, 2006 at 1:55 am
    I would use Boris or Marquee. There are terrific presets there you can adjust to taste.
    Officially, not “outside” of the program. 😉
    Cre8tive
  • Dave Schweitzer
    March 22, 2006 at 7:10 pm
    One thing you can try using the Title Tool is to create a title with a soft white drop shadow of say 8. Make the fill color fully transparent, and you’ve got a blurred avid title. Edit the title into your sequence, then step into the title and replace the graphic fill with something: some video, a still image, a pattern… when you step back up to the sequence your Avid title now has a soft edge and is filled with whatever you’d put in there. Sometimes I’ll put a move on the graphic fill so there’s some motion inside the title. Experiment with this and you shouldn’t have to go outside the prog.
