Activity › Forums › Adobe Illustrator › Creating text outline path WITH warp arc.
  • Creating text outline path WITH warp arc.
    Posted by davin davin on June 20, 2024 at 10:21 pm
    I can’t figure out how to create text outline with warp. I use a plotter that needs outline path for cutting the image. I warped the text, no problem. Then select the type menu > create outline. But that outline is flat, does not include warp effect. What do I need to do to outline exactly as is?
    In this screenshot you can see that the outline path is different from the text as shown. The middle pane it the output layout for my plotter/cutter
    davin davin replied 2 years, 3 months ago 1 Member · 1 Reply
  • davin davin
    June 20, 2024 at 10:46 pm
    solved: flatten transparency of the text layer….for some reason
