Activity Forums Apple Final Cut Pro Legacy Creating text effect in fcp
  • Creating text effect in fcp
    Posted by Ewan Maccormick on March 6, 2013 at 8:49 pm
    Hi there,
    I have been trying to find out how to create this effect in FCP or in motion, but I cant even seem to articulate it enough to search for it.
    Basically, if you watch this at 5 seconds in the text effect I am looking for begins. this clip
    Basically it is pinning the text to move with something in the shot.
    I have tried it with keyframes in fcp but it looks jerky and awful and I wondered if there was a simpler way to do this in motion or in fcp.
    any help would be very much appreciated.
    Cheers
    Stephen Smith replied 13 years, 5 months ago 4 Members · 4 Replies
  • Shane Ross
    March 6, 2013 at 9:17 pm
    It’s called TEXT TRACKING, and is something you’d do in After Effects.
    https://www.youtube.com/watch?v=VrZefTHygNY
    Shane
    Little Frog Post
  • Mark Suszko
    March 6, 2013 at 10:11 pm
    Yes, you can do this in Motion by first applying a tracker to the footage, then any graphic you put in Apple Motion lock to the motion. Same as AE can do, but it may be a little simpler in Motion.
    Look for Stephen Smith’s tutorials on the COW tutorials page because I believe he shows how to do this there. Or ask Stephen straight-up in the Motion forum, where he’s like the G%D#$ Bat Man in terms of fast help when you need it. Great guy, good teacher.
  • Ewan Maccormick
    March 7, 2013 at 9:30 pm
    Thanks so much guys. A really great help. I will head over to the Motion tutorials now and have a look for stephens stuff.
    Cheers again for taking the time to respond.
    Ewan
  • Stephen Smith
    April 19, 2013 at 6:10 pm
    Mark,
    Thanks for the kind words.
    Yes, this is easy to do in Motion 4. I would recommend that you check out this tutorial: https://www.digitaljuice.com/djtv/detail.aspx?sid=470&sortby=&page=1&rpid=0&rvid=0&swid=0&searchid=0
    This is how it was done:
    -Text layer was added above the layer with the movie.
    -Match Move behavior added to text layer
    -Hit F2 to open Behaviors tab
    -Make sure Type = Transformation
    -Move the anchor point to the area you want to track
    -Select the Scale Adjust button so Position and Scale are enabled
    -You will get a new option below Anchor called “Rotation-Scale.”
    -Click on the Analyze button and best of luck.
    Stephen Smith – Follow me on Behance
    Utah Video Productions
    Check out my Vimeo page
