Activity › Forums › Adobe Illustrator › creating tables in Illustrator
  • creating tables in Illustrator
    Posted by Chris617 on May 22, 2005 at 6:39 pm
    Is there a way to create a table for print with Illustrator CS?
    Do tables have to be created with the pen tool? I’m having trouble
    using the Rectangular Grid tool to do this. . .
    Are you aware of a tutorial on how to create tables in Illustrator?
    Thanks for your help.
    Chris
    Kelly Johnson replied 21 years, 4 months ago 2 Members · 1 Reply
  • Kelly Johnson
    May 23, 2005 at 1:10 am
    What kind of problem are you having with the rectangular grid tool?
    Creating a table by drawing a line and then duping and using the Align palette to Distribute evenly is fairly quick if you need custom sizes, but you can also just use Rules beneath type for all your horizontals which will be automatic, and then add vertical where you want them.
