Activity Forums DVD Authoring Creating subtitle TIFFs
  • Creating subtitle TIFFs
    Posted by Benn Gunn on September 5, 2006 at 7:37 pm
    I’m authoring a project which requires a few subtitle tiffs to be displayed one piece of video. I’m fine creating a script for Scenarist to import all my tiffs, but I’m having trouble creating the tiffs themselves.
    I know I need to get the text to have the appropriate indexed colours so Scenarost can map to them. I tried using the method we use for creating highlight tiffs for menus 9converting a tiff to indexed colours, assinging the four colours for the highlight to use and converting back to RGB), but that gave me a really indistinct subtitle when displyed.
    Is there a particular font that I could use to optimise the above method? Or should I be doing it an enitrely different way? Obviously getting them done by a subtitling supplier would be easiest, but I wanna know how to do this myself for small projects of this kind.
    Any help much appreciated!
    Bouke Vahl replied 19 years, 11 months ago 2 Members · 1 Reply
  • Bouke Vahl
    September 8, 2006 at 12:35 pm
    What i do is render them in my own render engine to 24 bit, but if you can script Photoshop you’ll be fine too.
    Here is the trick:
    Create the titles (in RGB) on a pure white BG, with 168, 168, 168 grey font and add a pure black border.
    If you must, scale them to the desired output resolution.
    Next, apply the DVD Subpicture plugin from Chris Linke. https://home.comcast.net/~c.linke/dvdsub/
    It will map the colors to pure colors, giving you one color for anti-aliasing between the border and the text. Map the colors in your DVD authoring application where you set the anti-aliasing to grey 100%, and you have the best possible titles.
    Hth,
    Bouke
