Activity Forums Apple Final Cut Pro Creating split screen using masks
  • Creating split screen using masks
    Posted by Eli Hollander on July 9, 2011 at 8:20 pm
    Okay… I think I finally figured it out, but I want to double check to see if there is an easier/better way.
    I want to create a split screen (2 or more screens) where the framing of video within each clip can be re-framed easily, without changing the border of the split.
    In FCP 7, to create split screen (where I can easily reframe the image within the split), I have done the following (two create a two screen split… for more screens, just add to the recipe :
    1. Place Masks Left on track V1
    2. Place Video 1 on track v2
    3. Place Mask Right on track v3
    4. Place Video 2 on track v4
    5. Apply “Travel Matte-Alpha to video tracks (v2 and v4).
    Done… now I can change video position without changing split position.
    On FCP X, the above recipe doesn’t work, and I haven’t found a way to do it without compound clips
    On FCP X I do:
    1. Place Video 1 on main story line (call it track v1)
    2. Place Mask Left above (call it track v2)
    3. Place Video 2 above (call it track v3)
    4. Place Mask Right above (call it track v4)
    5. Apply “Stencil Alpha” to Mask Layers (tracks v2 and v4)
    6. Make layers v1 and v2 compound clip
    7. Make layers v3 and v4 compound clip
    Done. Now to adjust the framing of each video, all I have to do is double click on the compound clip and adjust the video framing.
    Is there an easier way (and I hope the above makes sense)?
    Thanks.
    Eli
    P.S. This is a great forum. Thank you, everyone.
    Andre Van berlo replied 14 years, 5 months ago 7 Members · 17 Replies
  • 17 Replies
  • Rick Lang
    July 9, 2011 at 8:25 pm
    Simply use the new Crop tool on multiple clips such as the main stirrings and other clips above that. Why stop with only a split screen as this should allow you to gave more than two clips displaying simultaneously in their respective area of the screen.
    Rick Lang
    iMac 27” 2.8GHz i7 16GB
  • Rick Lang
    July 9, 2011 at 8:28 pm
    Apologies for the iPhone induced typos. I meant to say “storyline” not “stirrings”. Auto correction isn’t always helpful.
    Rick Lang
  • Rick Lang
    July 9, 2011 at 8:37 pm
  • Ethan Young
    July 9, 2011 at 11:54 pm
    https://www.crumplepop.com has a nice split screen plugin that automates many of these steps.
  • Eli Hollander
    July 10, 2011 at 12:29 am
    –crumplepop split screen plugin is for FCP7, not X.
  • Eli Hollander
    July 10, 2011 at 12:40 am
    Thanks for your suggestions, Rick.
    Of course cropping is a quick and dirty solution, but you can’t reframe the image (or substitute) within the crop without messing up the alignment of your split (unless I’m missing something).
    Also, eyeballing and cropping won’t line up if you’re doing a lot of cutting and re-framing (or resizing the image withou changing the border of the split).
    Also, what I outline above is of course extensible and flexible, limited by the the number and shape of the masks and the associated videos.
    I’ve been experimenting successfully with generating templates in motion that are pre-set for various borders and shapes.
  • Brendan Gibbons
    July 10, 2011 at 12:45 am
    Something to simplify this process can be built in motion.
    You could build a motion project that contains 2 groups (left group and right group etc), then add a Object> New Dropzone into each group, and then each group has it’s own mask, one for the left hand split and one for the right hand split.
    The crucial bit is to add the mask to the group and not the dropzone. By doing this you will have the ability to reposition the video without affecting the mask.
    You then publish this motion project, making sure you tick the box that mentions about publish as fcp generator.
    Now back in FCP X you can drop your generator onto the timeline, access the generator inspector where you will have to dropzones. It’s always a good process to rename the dropzones to something that’s useful to remind you which is which.
    The only problem with going the dropzone route is that if you clips have sync audio you’ll need to manually edit that back in yourself.
    Hope this has been of some help.
    If you don’t have motion 5, I can put together a sample that you can download tomorrow when I’m back in front of box.
    Cheers,
    Brendan
  • Brendan Gibbons
    July 10, 2011 at 12:48 am
    [Eli Hollander] “I’ve been experimenting successfully with generating templates in motion that are pre-set for various borders and shapes.”
    I just posted a reply without seeing this post….seems like you have it under control by using motion. It’s the definite way to go I think for things like this.
    Cheers,
    Brendan
  • Mark Spencer
    July 10, 2011 at 3:51 am
    You should also publish the Position parameters of each drop zone so you can adjust the position of the video inside the mask.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Eli Hollander
    July 10, 2011 at 5:04 am
    Brendan and Mark, thank you. I am just getting into Motion, and that generator solution sounds great, especially if it will let you reposition the video.
    Brendan, thanks for your offer–it will be great if you could mock soothing up if you have the time, as I am don’t know how to make a drop zones yet, but I can see how that would be a big (and flexible) time saver.
    I can then see that it’s possible to make several permutations of this that could be very useful (if you need split screens, that is).
    Thanks for your input and suggestions.
    Eli
