Activity Forums Adobe Premiere Pro Creating sequences in Adobe Premiere that are 5 frames per second 5 fps and ProRes 422 (HQ)
  • Creating sequences in Adobe Premiere that are 5 frames per second 5 fps and ProRes 422 (HQ)
    Posted by David Notowitz on July 10, 2015 at 9:31 pm
    Friends,
    You have always been so helpful! Thank you ahead of time.
    I am trying to create a custom sequence in Adobe Premiere Pro that will play ProRes 422 (HQ) at 5 fps.
    Is this possible?
    I’d prefer to not change the sequence from ProRes 422 (HQ) into another format, but do I need to change it?
    What is your advice?
    All the best,
    David Notowitz
    NCAVF, The National Center for Audio and Video Forensics
    https://www.NCAVF.com
    Trent Happel replied 11 years, 2 months ago 3 Members · 3 Replies
  • Ann Bens
    July 10, 2015 at 10:06 pm
    Nope, you cannot go any lower then 10 fps in a sequence.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • David Notowitz
    July 10, 2015 at 10:18 pm
    Ann, thank you for your response. Are you saying there is no way to create a 5fps sequence at all, or is the limitation only because I’m using ProRes?
  • Trent Happel
    July 11, 2015 at 9:51 pm
    10 fps is the lowest frame rate allowed for any Sequence.
    Trent Happel
    Adobe
    Premiere Pro
