Activity Forums Adobe After Effects Expressions Creating Scripts with prompts
  • Creating Scripts with prompts
    Posted by Chris Orcfilm on December 13, 2013 at 4:39 am
    So, for some reason I cannot find any resources online so I am asking you,
    is there a good resource/tutorial that explains how you can create scripts that you can save and run later that will apply a preset, but give you the opportunity to prompt the user for required information/parameters that is later used in the preset?
    Kind of like a Wizard that steps the user through the process and may create compositions as required along the way?
    I know it can be done, just have no idea where to start. Maybe there is a book?
    Thanks for reading this and for forgiving my ignorance.
    Cheers,
    Chris
    Orchard Film Studios, Canada
    Xavier Gomez replied 12 years, 9 months ago 2 Members · 1 Reply
  • Xavier Gomez
    December 14, 2013 at 8:50 pm
    Help > Scripting Help…
    links you to more or less everything you need to start scripting, but it’s a lot of things to read so here is some résumé:
    information about scripting for After Effects is all included in the After-Effects-CS6-Scripting-Guide.pdf, but it does not include UI stuff. UI related things are a topic on their own which is covered in the JavaScriptToolsGuide_CS5.pdf
    Now these ressources are very detailed, most of the time you will find answers to your questions there, but they are also a bit dry (just a bit) and it is more useful to start with some concrete examples. It is less and less easy to find open code scripts but there are some. Dan Ebberts’ site:
    https://www.motionscript.com/ae-scripting/table-of-contents.html
    gives a few tutorials/examples to get started and see how it works. Then build upon that and the guides.
    The adobe scripting forum is also helpful:
    https://forums.adobe.com/community/aftereffects_general_discussion/ae_scripting?view=discussions&start=30&numResults=30#/
    I was about to forget!! On the Adobe forum you will find David Torno’s video tutorials which will lift you from absolute beginner to Senior Coder in 19 Episodes:
    https://forums.adobe.com/message/5585539#5585539
    Xavier
