Activity Forums Adobe After Effects Creating Sand Blowing an object away
  • Creating Sand Blowing an object away
    Posted by Elias Huch on May 11, 2007 at 2:06 am
    OK,
    So I tried the tutorial by Emanuel Eriksson for sand that blows text away. It didn’t work. I’m not sure if I was doing something wrong or what, but I was trying to figure out the mechanics of it so I can apply it to a project I’m working on right now. I could really use some help. This could be the difference between staying or going at my new job. So here’s what I need to do;
    I have a solid graphic that will be branded for everything that has to do with a particular series of shows. I want to be able to have it blow on “like sand” and then blow off again, revealing text such as a lower third. I know there is a way to do this, but I just can’t figure it out. Would really appreciate any input.
    Thanks everyone
    Elias Huch replied 19 years, 4 months ago 3 Members · 3 Replies
  • Mike Clasby
    May 11, 2007 at 6:46 am
    Trapcode Particular
    Building Up Particles
    https://www.creativecow.net/articles/lee_james/particle_build_up/index.html
    Particle Illusion (30 day fully functional trial, methinks)
    Disintegrating People and Other Things
    https://www.creativecow.net/articles/deane_elvis/disintegratePeople/index.html
  • Rhett Robinson
    May 11, 2007 at 4:39 pm
    What part of it “doesn’t work”? I used this trick a few years ago, and had a skeleton exhaling smoke that blew text away, added a little 3D, and it was DYNAMITE! It did render VERY slowly, especially compared to one of the particle generators listed… of course, I was using a G3 iBook back in the day, and really overdid it on the quality.
    Let me know what you are getting… is it an error, or what happens?
  • Elias Huch
    May 12, 2007 at 9:05 pm
    I have actually been trying to use tr particular and it seems like it may be what I need. As for the tutorial from earlier, I must have been doing something wrong. I will try it again. Thanks for your help guys!
