Activity Forums Adobe Premiere Pro Creating Safe Action Area for Network Bug
  • Creating Safe Action Area for Network Bug
    Posted by Katherine Linhardt on January 18, 2017 at 6:23 pm
    Hello! New to Creative Cow but hoping someone may be able to help me what seems like it should be a fairly straightforward task but I am struggling to figure out how to do it in Premiere. I was given specs from a network that there will be a transparent logo on screen during the broadcast of our show and the specifications for insertion of the Logo is as follows:
    The H (horizontal) location, measured across the middle of the Logo, within the 0 to 1919 active H pixels is, LEFT 1402, RIGHT 1607. The V (vertical) location in interlaced field lines is, TOP, line 1054 (field 2) BOTTOM, line 1096 (field 2). This translates within the 0 to 1079 active V pixels to, Start 941, End 1025.
    If someone can help me translate/measure this in Premiere or After Effects I would be very grateful. Thanks!
    Kate
    Katherine Linhardt replied 9 years, 8 months ago 3 Members · 5 Replies
  • Daniel Waldron
    January 18, 2017 at 7:10 pm
    Can you ask your network contact for a visual aid? I’m working with a network now and they sent a 1920×1080 PNG that shows the text safe areas and where the bugs will be.
  • Jeff Pulera
    January 18, 2017 at 8:37 pm
    Hi Kate,
    Just so we’re on the same page – are you inserting the logo, or is the network simply providing a heads-up that THEY will be inserting a logo, perhaps so you don’t put any titles in the same area? I think it’s the latter, right?
    Please find attached a 1920×1080 overlay that you could drop onto a higher video track in your Premiere timeline. It has a semi-transparent yellow box for the coordinates you provided (made this in PS). Hope it is correct. You could just toggle this layer on/off just to check your work, as a visual aid.
    Jeff Pulera
    Safe Harbor Computers
  • Jeff Pulera
    January 18, 2017 at 8:42 pm
    This is weird – I’d saved image as .png with alpha from PS, and double-checked and alpha is intact, yet when I do the “Save As…” from this site, background is white. Created a new image, maybe it will work this time?
    Jeff Pulera
  • Jeff Pulera
    January 18, 2017 at 8:50 pm
    Sorry, image I am uploading is verified correct with alpha, yet the site kills the alpha somehow…just tried .psd and .tga, both report unsupported file type, as did .pdf
    Jeff Pulera
  • Katherine Linhardt
    January 18, 2017 at 9:07 pm
    Thank you so much, Jeff! This is perfect, such a huge help. The network will be putting it in themselves, but asked us to confirm that we have QC’d with this in mind. I just threw in a jpg and reduced the opacity to see it over the video, I appreciate the alpha though!
    Best,
    Kate
