Activity Forums Apple OS X Creating Quicktime Skin
  • Creating Quicktime Skin
    Posted by Colin Williams on March 28, 2006 at 9:03 pm
    I recently finished all the steps in this tutorial for creating QuickTime Media Skins:
    https://www.apple.com/quicktime/tutorials/mediaskins.html
    For some reason when I attempt to open the final xml file, it says “QuickTime cannot open the file: “skin_xml.mov”
    it is not a file that QuickTime understands (-2048)”
    I checked the xml code and rechecked it again and can’t seem to open it. Any light on this darkness would be great!
    I’m using a G5 dual 2ghz, QuickTime Pro 7.0.3, OSX 10.3.9, Photoshop CS
    Colin Williams
    https://www.pensivecrow.com
    Damien Kelly replied 20 years, 5 months ago 3 Members · 3 Replies
  • Matt Larson
    March 29, 2006 at 11:25 pm
    I never had much luck with skinning through QuickTime, or with QTVR. Check out LiveStage https://www.totallyhip.com/livestage.asp It’s a bit pricey, but it will probably let you do things you never knew you wanted too. They have a free 30-day demo you can play with
  • Colin Williams
    April 3, 2006 at 5:12 pm
    Thanks. I’ll have to check it out. It looks as though you can do some really interesting things with it. I was under the impresson that QT with some xml code was capapble of doing almost the same thing.
  • Damien Kelly
    April 5, 2006 at 8:49 am
    Hi Colin.
    You may need to save the file as plain text.
    In TextEdit go to Format>Make Plain Text then save it again.
    Change the extention to .mov and you should be good to go.
    Damo.
