Activity › Forums › Adobe Premiere Pro › Creating Proxies from Sony FS5 4K footage
  • Creating Proxies from Sony FS5 4K footage
    Posted by Mark Krueger on October 26, 2017 at 12:00 pm
    When I try to create a proxy file for FS5 Sony 4K clip I get an error message regarding the 4 channel audio being not compatible. Therefore it does not generate a proxy file. Any ideas here?
    Greg Janza replied 8 years, 11 months ago 3 Members · 5 Replies
  • Johnny H
    October 26, 2017 at 2:18 pm
    Mark,
    I have not had this issue but below is a link to the setting I have had success with when making proxies for FS5 4K. This is using the ProRes 422LT codec.
    Ingest Preset Proxy ProRes 422 LT for F5 (4096 X 2160) to 1024 X540 Ingest.epr
    https://www.dropbox.com/s/ps5154dt04fn92g/Ingest%20Preset%20Proxy%20ProRes%20422%20LT%20for%20F5%20%284096%20X%202160%29%20to%201024%20X540%20Ingest.epr.zip?dl=0
    John Hudson
    Bright Light Visual Communications
  • Greg Janza
    October 26, 2017 at 5:22 pm
    Your proxies have to match the 4k files exactly with regards to audio channels. If you have 4 channels of audio on the 4k files then your ingest setting must also be four channel. When I made proxies I had to create custom ingest presets with correct audio channel information because the default ingest options didn’t have 4 channel audio. You create the custom ingest presets in Encoder and then export the preset to a location that you can steer to in the proxy settings pop up in premiere.
    I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
    – Orson Welles
  • Mark Krueger
    October 27, 2017 at 3:05 am
    Thanks Greg. I will give that a try!
  • Mark Krueger
    October 30, 2017 at 2:42 pm
    Greg… I cannnot find where I can create custom presets for 4 channel audio… Can you give me a few directions or send some links to good tutorials on this. Thanks Mark
  • Greg Janza
    October 30, 2017 at 3:52 pm
    https://blog.frame.io/2017/03/20/premiere-pro-proxies/
    – Orson Welles
