Activity › Forums › Adobe Premiere Pro › creating project for 16.9 and 4.3 on single disc
  • creating project for 16.9 and 4.3 on single disc
    Posted by Chris Alexander on February 27, 2007 at 3:31 pm
    I’m starting a small project, using stills, that I would like to create in 2 forms. One, 16.9 version which will fit 16.9 TV sets and another that will show the 16.9 format in a standard 4.3 TV set. Is there a way to do this in Premiere Pro 2 without having to create 2 separate projects (16.9 and 4.3 ratio). If possible I would like to create it in a 16.9 workspace. Any help or suggestion would be appreciated.
    Blast1 replied 19 years, 7 months ago 3 Members · 2 Replies
  • Aanarav Sareen
    February 27, 2007 at 5:13 pm
    [Chris1954] “Is there a way to do this in Premiere Pro 2 without having to create 2 separate projects (16.9 and 4.3 ratio).”
    Nope. You will have to create 2 separate projects.
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Blast1
    February 27, 2007 at 8:05 pm
    [Chris1954] “I’m starting a small project, using stills, that I would like to create in 2 forms. One, 16.9 version which will fit 16.9 TV sets and another that will show the 16.9 format in a standard 4.3 TV set.”
    Just make a 16:9 project and burn to DVD as such, most DVD players except some old ones will play the 16:9 on wide screen sets and automatically letterbox the footage for 4:3 if it doexn’t detect a widescreen.
