Activity › Forums › Adobe After Effects › Creating “police car lights” effect
Posted by Lyle Pascoe on May 20, 2008 at 3:19 pmHi,
i am looking for an old tutorial on creating the light effect that mimics police car lights flashing against a wall.
or if you have an easy way of doing this I would greatly appreciate it.
regards
Lyle
Aqeel Sami replied 16 years, 6 months ago 3 Members · 5 Replies -
John Cuevas
May 20, 2008 at 8:19 pmI’m guessing Dave that you are using the box as a “lighting projector”. If so, the all the boxes along with the lighting transmission set to 100% also need the “cast shawdows” property turned to “only”, so that the red is projected.
Johnny Cuevas, Editor
http://www.ckandco.net -
Lyle Pascoe
May 21, 2008 at 8:01 amWell if you say it like that it sounds too easy!
i should have thought of that.
Lyle Pascoe
May 21, 2008 at 9:24 amOk I made the light box and set the rig up as per your instructions but the “light box” is not casting light onto the background layer.
I am using a point light. If i adjust the layers to cast shadows only that layer (with the red dot) disappears.
And I thought this was going to be easy…
Lyle Pascoe
May 21, 2008 at 11:00 amOk, My bad.
I forgot to switch on the background layers 3D on.
It works great.
