Activity Forums Maxon Cinema 4D Creating Point Selections from Images
  • Creating Point Selections from Images
    Posted by Will Macneil on August 1, 2005 at 12:23 pm
    Hi, is there a way to use an image (possibly applied as a material) to create point selections? Ideally this would work on a luminance basis. I know this is kind of a wierd one (mixing the 2d and 3d worlds) but I thought it was worth a shot.
    Will
    Jack Cook replied 21 years, 1 month ago 4 Members · 5 Replies
  • Chris Smith
    August 1, 2005 at 2:33 pm
    There’s probably a much slicker way, but I wonder if you use the image deformer on a plane so that it will say raise the points that are lighter. Then you can square marquee them in a front view window.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Will Macneil
    August 1, 2005 at 3:24 pm
    Sorry, I haven’t heard of the image deformer. Am I missing something?
    Will
  • Chris Smith
    August 1, 2005 at 4:45 pm
    Sorry, after actully opening C4D to look, it’s not a deformer but an object primitive called ‘relief object’. It can be found under either primitive menu.
    Chris Smith
  • Colinmcd
    August 2, 2005 at 11:49 am
    Are you wanting to use a 2D image to ‘trace’ over to then go onto create a 3D model – i.e. place the points and then bridge them to make polys?? You can do this by going to the relvant viewport (within C4D) you have the original image in i.e. LH elevation etc and then click on ‘edit’ within the viewport, select ‘Configure’ and then click on ‘Back’ from the attributes slections and add the path of the image in.
    Here’s a link to a plugin that does it a slightly different way.
    https://www.c4dplugs.com/viewPlug.php?RECORD_KEY%28PluginsRec%29=ID&ID(PluginsRec)=388&PHPSESSID=be00f09abfdab9b31fefbddd0a42b508
    Cheers,
    Colin
  • Jack Cook
    August 3, 2005 at 12:03 pm
    You can also try the Vectorizer object, which is found in the spline objects menu.
    Jack
