Activity Forums Adobe After Effects creating paper
  • Walter Soyka
    May 28, 2013 at 3:02 am
    That’s going to be a bit tricky in Ae alone. I’d guess most of the heavy lifting there was done in a 3D application.
    I’ve done a few projects with paper effects and leaned pretty heavily on Mettle FreeForm — though you can get away with a lot more than you’d expect with CC Page Turn if you use multiple instances on the same layer.
    Walter Soyka
  • Malcolm Desoto
    May 28, 2013 at 4:06 am
    hmmmmmm, curious. I hadn’t heard of the mettle plugin before. That may be worth exploring. It looks like it may be able to do exactly what I want.
  • Walter Soyka
    May 28, 2013 at 4:19 am
    [Malcolm DeSoto] “hmmmmmm, curious. I hadn’t heard of the mettle plugin before. That may be worth exploring. It looks like it may be able to do exactly what I want.”
    You may have it. FreeForm was bundled with AE CS5 and CS5.5.
    It’s no longer included with CS6, but it rocks. Very useful and flexible effect.
    Walter Soyka
  • Tudor “ted” jelescu
    May 28, 2013 at 9:53 am
    FreeForm will not only help you roll the layer in 3d space but you can also displace the surface using a displacement map that will help create the crumpled paper look.
    Here’s a tutorial you may find useful:
    https://library.creativecow.net/jelescu_tudor/3D-from-2D-image_AE/1
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Bobotis
    May 28, 2013 at 10:20 am
    Tudor, Walter, thanks for pointing this out 🙂
    You can find some free project files for FreeForm V2 and FreeForm Pro here: https://www.mettle.com/free-presets-and-project-files/
    More to come very soon.
    Cheers,
    Chris
    mettle.com
