Activity › Forums › Compression Techniques › Creating PAL DVD
  • Creating PAL DVD
    Posted by James Whittington on June 14, 2009 at 7:46 pm
    Hello,
    I am supposed to create a PAL DVD using a bunch of NTSC quicktime movies.
    It seems I have to convert each quicktime to PAL first. Can this be done correctly using compressor or after effects? Once that is done, then I can use DVDSP to create a PAL DVD yes?
    Any help on the steps necessary to accomplish this would be greatly appreciated!
    Daniel Low replied 17 years, 3 months ago 4 Members · 4 Replies
  • James Whittington
    June 15, 2009 at 3:35 pm
    Here’s what I am trying using compressor….
    Format: DV-PAL
    Width: 720
    Height: 576
    PAR: PAL CCIR 601 (16:9)
    Frame Rate: 25
    If I use these settings on all my QTs and then create a DVD in studio pro using the PAL settings, then I should have a functional PAL DVD in theory. Right?
  • Chris Blair
    June 16, 2009 at 2:18 am
    You could convert all the NTSC movies first, or convert them on final output to MPG2. I’d limit the number of passes you make doing any sort of compression/re-sizing to the least number possible.
    I’m not sure compressor is going to do the best job at resizing, but others on the list might be better able to answer that.
    Also…depending on your source material, converting from NTSC to PAL could introduce some motion artifacting since you’re resizing and changing the frame-rate. If the source is really high-quality and doesn’t have a lot of camera motion, it might look very good. If it’s marginal quality and there is a lot of camera movement or even movement within the frame, it could end up looking kinda iffy.
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
  • Rich Rubasch
    June 17, 2009 at 12:49 am
    We have had good luck using Nattress Standards Converter right in FCP. It is a unique workflow so follow the steps closely but you will have good results. Export the PAL clips and encode in compressor…compressor will see that theya re PAL and encode accordingly. AC3 encoding does not change.
    Then author in DVDSP as a PAL disc.
    Voila.
    Rich Rubasch
    Tilt Media
  • Daniel Low
    June 17, 2009 at 10:03 am
    [Rich Rubasch] “Nattress Standards Converter”
    Agreed, that’s the way to go if you can’t afford the use of a professional standards converter.
    Two years from now, spam will be solved. – Bill Gates, World Economic Forum 2004
