Activity Forums Apple Final Cut Pro Legacy Creating Own Effect
  • Creating Own Effect
    Posted by Espnetboy3 on February 8, 2007 at 11:45 pm
    Hey guys I have been learning some Avid the past few days and created a 8 frame filler which I thought was like a slug. Although on this Filler I added a glow effect and keyframed it from zero then in the middle 100 then back to zero so it would be a nice little transition. I just add it on a track above the clips in between the edit.
    Is there a way to create your own effects/transisitions like this in FCP. I know you can save Transitions but not sure how. I do use copy/paste attributes if i get a look i desire for once clip.
    Andreas Karoliussen replied 19 years, 7 months ago 2 Members · 1 Reply
  • Andreas Karoliussen
    February 12, 2007 at 12:59 am
    You can create your own effect in FCP – using your FX builder right in FCP, however that’s tricky and takes time and skill in code writing.
    The easier way is to customise an effect: make your personal tweaks and art. Then drag your filter / transition from your sequence to your favorites bin.
    Or you can even create a separate project for your effects and save them there. That way they don
