Activity Forums Adobe After Effects Creating ‘outer roundness’ for rectangle shapes.
  • Creating ‘outer roundness’ for rectangle shapes.
    Posted by Amir Aizat on August 13, 2019 at 10:45 am
    Hi, I’ve been trying to figure out how to create this outer roundness shape in After Effects, but I can’t find an efficient way to do so. What’s a good way to create this shape in AE? I’ve tried Simple Matte Choker but it’s hard to get a predictable result.
    Amir Aizat replied 7 years, 1 month ago 2 Members · 4 Replies
  • Cassius Marques
    August 13, 2019 at 1:38 pm
    You can use rounded rectangles in shape layers. Combining them with mask modes.
    Cassius Marques
    http://www.zapfilmes.com
  • Amir Aizat
    August 14, 2019 at 9:05 pm
    Hi Cassius,
    I was thinking of the same thing, but I have this issue:
    https://imgur.com/Z2RaHt0
    It’s at the end of the gif, where the connected illusion breaks.
    The problem with masks I’m facing so far is that it’s not good enough, at least to my knowledge, to maintain this illusion of continuity at smaller gaps.
    View post on imgur.com
  • Cassius Marques
    August 15, 2019 at 11:54 am
    I can see the problem, but with AE that’s what you get. Unfortunately as far as I know we don’t have access to a plugin that rounds masks.
    But I’m sure you can correct that issue, at least visually so your animation works.
    Good luck.
    Cassius Marques
  • Amir Aizat
    August 16, 2019 at 8:55 am
    Hi Cassius,
    Thanks for your help, I settled for a compromise using Math.max(). Both boxes will become the same size if the gap is too small. It’s a bit of a hassle to set up with more than 2 boxes, but it is doable.
    It works and performs surprisingly well given the amount of expressions involved.
