Activity Forums Maxon Cinema 4D Creating normal maps from hi-poly mesh
  • Creating normal maps from hi-poly mesh
    Posted by Will Macneil on January 4, 2006 at 3:13 pm
    Is there a way to create a normal map from an untextured mesh? As far as I can see the only way to do this is using a bump or displacement maps. Unfortunately, I can’t create a suitable bit map to create the displacement/bump.
    Any suggestions?
    W
    Adamt replied 20 years, 7 months ago 3 Members · 4 Replies
  • Chris Smith
    January 4, 2006 at 5:43 pm
    With your 9.5 CDs on one of the other discs are tutorials if I remember correctly.
    here’s an online tutorial:
    https://members.shaw.ca/jimht03/normal.html
    Chris Smith
    https://www.sugarfilmproduction.com
  • Chris Smith
    January 4, 2006 at 5:46 pm
    Sorry, after looking closer at the online tut, it’s old skool method. Not using the new 9.5 tools.
    Chris Smith
  • Will Macneil
    January 5, 2006 at 10:45 am
    If I’m looking at the right thing, the video tutorial on the 9.5 cd is for creating normal maps for the gnome which has already got a displacement map applied. What I want to do is create a normal map from a mesh – a model with no texture applied.
    W
  • Adamt
    January 5, 2006 at 4:23 pm
    Cinema doesn’t have the ability to create a normal map for a low-poly object based upon a higher-poly object–except for the displacement method. There is a plugin that provides this function: https://www.cinemax4d.de/simplemakerpro/home_us.html
    Or if you have ZBrush, that’s probably the best way to do it.
