Activity Forums Apple Final Cut Pro Legacy creating muxed MPEG file from FCP
  • creating muxed MPEG file from FCP
    Posted by Michael Williams on July 16, 2011 at 9:50 pm
    I have a series of videos that need to be encoded to the following specs (from the end user)
    “Standard Definition MPEG Parameters
    – MPEG1 or MPEG2 files must be encoded as a Program Stream.
    -Elementary Video stream must be Main Profile Main Level MP@ML 4:2:0.
    -Elementary Audio Stream is optional and must be MPEG layer II at a frequency of 44100Hz with 192kbps.
    -Constant Bitrate CBR
    -The main resolution supported is 720 x 480. (16:9 Resolutions are supported based on Television)
    -Supported Bitrates between 4 – 6 Mb/s normally provide good quality SD images and is preferred”
    I am using FCP 6.0.6 and trying to use either Quicktime, Compressor or MPEG Streamclip (or some combination) I thought Compressor would be the easiest, but when I use the multiplexing option, it does not allow me to alter the frequency or bitrate of the audio. So, I thought I could do the video in compressor and create the audio elsewhere, then mux the files in MPEG Streamclip and I can’t seem to make that work.
    cut to the chase…does anybody have a good working solution for delivering to these specs?
    FCP 6.0.6
    MacPro with OS 10.5.8
    thanks much.
    mike
    Michael V. Williams
    producer/editor
    http://www.vernonvision.com
    Michael Williams replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
