Activity › Forums › Apple Final Cut Pro Legacy › creating mpeg-2 – why no audio?
Posted by J. Tad newberry on May 21, 2010 at 4:18 pmA network wants our show delivered via ftp as an mpeg-2, but whether i tried it out of an FCP timeline via Compressor, or make a QT them drop it onto a droplet, i get a video with no audio. Any help?
David Roffman replied 14 years, 6 months ago 9 Members · 13 Replies -
Michael Sacci
May 21, 2010 at 4:48 pmand all you compressor settings are?
Have you setting Multiplexing in the Extras tab?
Michael Cheung
May 21, 2010 at 5:56 pmIf you’re using the Elementary Stream setting in Compressor I don’t think it’ll export audio.
Michael Cheung
Editor/Assistant Editor/DIT
J. Tad newberry
May 21, 2010 at 6:13 pmsettings are all default mpeg-2 (Program stream) Compressor settings
Extras / Multiplexed MPEG-1/Layer 2 Audio is checked and Program Stream selected (both of these by default)
thanks for the attention
Thanks again!
J. Tad Newberry
Big Ya Productions
Mac Pro 2.66 GHz Quad-Core
3 GB RAM
http://www.bigya.tv -
J. Tad newberry
May 21, 2010 at 6:15 pmdelivery specs specify “CBR Bitrate: 8Mbs” and the default Compressor setting was two pass VBR, avg 15Mbps and Max at 20Mbps, so it seems to be making the video at a high enough quality, though on playback, it sure doesn’t look like something i would want to air! : )
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
Steve Eisen
May 21, 2010 at 7:47 pmEpisode Pro from Telestream!
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group -
Michael Gissing
May 22, 2010 at 1:00 am8Mbs is normal for SD if that is what is required. If the specs ask for CBR 8Mbs, why are you using VBR at higher bit rates?
Chris Babbitt
May 22, 2010 at 7:36 pmTry Transport Stream. That’s what I use, and I get audio every time.
Rafael Amador
May 23, 2010 at 2:26 amHi Tad,
The audio is there, but QT can not play it.
Play the file with MPGStreamclip to check that.
rafael -
Roy Stewart
September 1, 2010 at 2:45 pmI am trying to make an MPEG-2 file from a quicktime movie using Compressor and the video is fine but there is no audio. I have tried to make it exporting straight from Final Cut Pro and also just as a self contained quicktime movie – and no joy either way. Anyone any ideas? All suggestions very, very welcome.
Roy Stewart
September 1, 2010 at 4:45 pmHi Dave
I used both Programme and Transport Streams, both unsuccessfully. Video in MPEG2 fine – but no audio.
The audio is just part of the preset MPEG audio @ 48kHz.
To give the full background. I filmed on XDCAM HD and made the movie in final Cut Pro an an HD movie. I have tried making self contained and reference qt movie files and imported them to Compressor – and also exported direct from FC Pro into Compressor. Nothing works. The resultant MPEG2 video is fine – but the audio just disappears. HELP!!!!!!!!!
