Activity Forums Adobe After Effects Creating Mis-Aligned Text
  • Creating Mis-Aligned Text
    Posted by Gates Bradley on February 1, 2013 at 12:14 am
    I’m trying to do something that is hard to search for, so apologies if this is redundant to another thread.
    I’m trying to create mis-aligned text in After Effects so that the text looks not like it was laid out digitally (everything on a very straight line), but so that each line, and to a lesser extent, each character, is slightly misaligned with it’s neighbors, the same way it would be if a person was writing.
    There’s some ancient documents I have to create. I’ve got the look down, save for the text’s being perfectly aligned. I’ve tried turbulent displacement to varying degrees of success but it’s still not quite right. The text is seen in an extreme CU, so cheating is a bit tougher than usual.
    Much obliged for any suggestions.
    Gates Bradley replied 13 years, 7 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 1, 2013 at 5:24 am
    Use a wiggly selector and a text animator for character position:
    https://helpx.adobe.com/after-effects/using/animating-text.html#text_animator_properties
    After Effects team blog
  • Gates Bradley
    February 1, 2013 at 8:24 pm
    Sure thing Dave! Let me elaborate…
    The writing is in Greek. I found a font that has support for Greek characters that looks relatively legit as a handwritten font. Actually handwriting the text would be a huge pain. There is no animating on of the text, but there is a camera move over the text (think macro lens).
    I chose to make the text in After Effects 1) because I still think it handles text creation better than Illustrator or Photoshop, and 2) because I need to make templates for a number of texts, and it’s easier to manipulate/make changes keeping it all in one program than bouncing back from Illus./PS to AE. (That being said, if creating misaligned text is a much easier process within either of those Apps, I’d give it a go).
    Hope that clarifies things a bit.
