Activity Forums Adobe Premiere Pro Creating markers from a list of timecode
  • Creating markers from a list of timecode
    Posted by Caleb Mclaughlin on December 10, 2012 at 12:09 am
    Hey everyone. The short story is:
    I have a list of timecode locations that I want to create markers from.
    The long story:
    I’m converting old VHS tapes, and I’m ending up with 6hr AVI files. The plan is to archive it all categorically. I found a German program called AVCutty (thank you CreativeCow for that one), and it does a pretty good job of scene detecting the footage. From there, I can export AVI files of each scene, and that’s all well and good except except that it takes a good chunk of time and I have a TON of VHS tapes, and I’d like to avoid having too many files floating around. In order to simplify my workflow, I want to create markers in my Premiere Pro (CS6) timeline, and then split and encode the footage from there (and that way I can make sure the edit points are all correct). AVCutty can export a CSV file, which I can then put into a spreadsheet and have the location of every edit point at my fingertips. However, unless I can find a good way to make markers from it, it does me no good.
    Any good ideas or workarounds?
    P.S. I can also export the list to AVCutty proprietary format (.scn), Vegas EDL (which are .txt files), and AVISynth Script (.avs)
    Caleb
    Caleb Mclaughlin replied 13 years, 8 months ago 2 Members · 3 Replies
  • Angelo Lorenzo
    December 10, 2012 at 2:04 pm
    What does the Vegas EDL look like? Can you paste a portion?
    If it looks like a standard EDL then you could rename the extension to .edl, import it into Premiere, and relink the footage.
    Exporting individual cuts within Premiere is very cumbersome. I may import the sequence into After Effects and use scripts (I’m sure one exists) to split the layers into individual comps that you can queue for encoding.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Caleb Mclaughlin
    December 10, 2012 at 4:12 pm
    [Angelo Lorenzo] “What does the Vegas EDL look like? Can you paste a portion?”
    You know, up until now, I’ve never used or looked into EDL’s. I will poke around with that when I get home tonight. You raise a good point about the chance of AE being a better tool for this too. I’ll follow up later tonight or tomorrow.
    Caleb
  • Caleb Mclaughlin
    December 11, 2012 at 1:03 am
    The Vegas EDL looks like this. Each chunk is one line of the EDL. I split each value into different lines so it could be understood easier.
    “ID”;
    “Track”;
    “StartTime”;
    “Length”;
    “PlayRate”;
    “Locked”;
    “Normalized”;
    “StretchMethod”;
    “Looped”;
    “OnRuler”;
    “MediaType”;
    “FileName”;
    “Stream”;
    “StreamStart”;
    “StreamLength”;
    “FadeTimeIn”;
    “FadeTimeOut”;
    “SustainGain”;
    “CurveIn”;
    “GainIn”;
    “CurveOut”;
    “GainOut”;
    “Layer”;
    “Color”;
    “CurveInR”;
    “CurveOutR”:
    “PlayPitch”;
    “LockPitch”
    1;
    1;
    0.000000;
    13580.206979;1.000000;
    FALSE;
    FALSE;
    0;
    FALSE;
    FALSE;
    VIDEO;
    “R:Captured VideoMyTapeMyClip005.avi”;
    0;
    0.000000;
    13580.206979;
    0.000000;
    0.000000;
    1.000000;
    4;
    0.000000;
    4;
    0.000000;
    0;
    -1;
    4;
    4;
    0.000000;
    FALSE
    I tried renaming the file from .txt to .edl, but all it did was create an empty sequence in Premiere. I’m going to try to figure out what a Premiere EDL looks like and see if I can modify the EDL’s that AVCutty puts out. Any thoughts?
    Caleb
