Activity › Forums › Maxon Cinema 4D › creating manure grains
  • Steve Bentley
    September 26, 2019 at 11:53 pm
    Oh man! I’m gonna have to clean my tape measure now!
    Real flow might be a big hammer for this but we’ll get to that in a sec.
    Depending on your angle of view on the scene, will you really be so close to the thrown particles so see enough detail? If you just emit particles with varying sizes, shapes and varying textures(colors) I don’t think your going to see a difference whether its lead shot or manure. If you need to cut to a close up of surface tension holding the stuff on the water then that’s a different story. (in that case particle “flats” with images maps on them floating radially out from the landing point and rotating would be a good illusion.
    As for using RF, (and in this case not using it) what about using a proximity tag to find where each particle hits the “water” surface and apply a deformer or shader deformer where those events happen? I assume that’s what you want RF for? This gets really easy in R 21 (and 20?) with Fields. But can be done with any version that has Mograph.
